Introdução
This will be a quick guide on how to replace the thermal paste of a Toshiba Satellite E45t-B4204. Replacing the thermal paste will help transfer the heat from the CPU to the heatsink and out of the laptop.
Peças
Não são necessárias peças.
Remove all of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
Locate and remove the four 3 mm screws around the CPU.
The CPU is located beneath the copper heatsink.
