Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Speaker Replacement
O que você precisa
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, imagem 2 %32 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: passo 1, imagem 3 %32
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 2, imagem 1 %32 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 2, imagem 2 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, imagem 1 %32 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, imagem 2 %32 Toshiba Satellite E45t-B4204 Speaker Replacement: passo 3, imagem 3 %32
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, imagem 1 %32 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, imagem 2 %32 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: passo 4, imagem 3 %32
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 5, imagem 1 %32
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the speakers.
Conclusão
Emily Bateman
Membro desde: 05/22/19
97 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G3, Wilson Summer 2019 Membro de IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
Membros da 4
Autoria de 6 guias
2 comentários
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.⏎
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.⏎
Any idea of what is the product code?⏎
Thanks
MagenOne - Responder
Looks this H000079200
MagenOne -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 695
