Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: passo 1, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: passo 1, imagem 3 %32
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 2, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 2, imagem 2 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 3, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 3, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 3, imagem 3 %32
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 5, imagem 2 %32
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 6, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 6, imagem 2 %32
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 7, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 7, imagem 2 %32
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 8, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 8, imagem 2 %32
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 9, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 9, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 9, imagem 3 %32
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 10, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 10, imagem 2 %32
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 11, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 11, imagem 2 %32
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 12, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 12, imagem 2 %32
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 13, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 13, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 13, imagem 3 %32
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 14, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 14, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 14, imagem 3 %32
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 15, imagem 1 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 15, imagem 2 %32 Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 15, imagem 3 %32
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 16, imagem 1 %32
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: passo 17, imagem 1 %32
    • Remove the keyboard.
Conclusão
Youdong Yan
Membro desde: 05/22/19
229 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G3, Wilson Summer 2019 Membro de IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
Membros da 4
Autoria de 6 guias
Um comentário
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 612
