Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Charging Port Replacement
O que você precisa
  1. Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: passo 1, imagem 2 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: passo 1, imagem 3 %32
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 2, imagem 1 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 2, imagem 2 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 3, imagem 1 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 3, imagem 2 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 3, imagem 3 %32
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Charging Port Replacement, Charging Port: passo 4, imagem 1 %32
    • Locate the charging port housing.
  5. Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 5, imagem 2 %32 Toshiba Satellite E45t-B4204 Charging Port Replacement: passo 5, imagem 3 %32
    • Unplug the charging plug housing from the motherboard.
Conclusão
Eduardo
Membro desde: 03/22/18
411 Reputação
Autoria de 4 guias
Equipe
Um comentário
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
Correy Smith Hartzog - REALTOR - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 3,126
