Ir para o conteúdo principal
Toshiba Satellite E45T-A4300 Motherboard Replacement
O que você precisa
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 2, imagem 1 %32
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 5, imagem 2 %32
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: passo 6, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: passo 6, imagem 2 %32
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 8, imagem 2 %32
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: passo 9, imagem 1 %32
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 10, imagem 2 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 10, imagem 3 %32
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: passo 11, imagem 1 %32
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: passo 14, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: passo 14, imagem 2 %32
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 15, imagem 1 %32
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 16, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 16, imagem 2 %32
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 17, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 17, imagem 2 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 17, imagem 3 %32
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 18, imagem 1 %32 Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 18, imagem 2 %32
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: passo 19, imagem 1 %32
    • Remove the motherboard from the device.
Conclusão
James Nguyen
Membro desde: 10/23/18
573 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G4, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G4
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 774
