Ir para o conteúdo principal
Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement
O que você precisa
  1. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: passo 2, imagem 1 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, imagem 1 %32 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, imagem 2 %32 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: passo 3, imagem 3 %32
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend the iFixit toolkit.
  4. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: passo 4, imagem 1 %32
    • Using the #0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive and remove the USB Port Circuit Board as shown.
Conclusão
Tori Ryals
Membro desde: 10/11/16
41 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-4, Leahy Fall 2016 Membro de USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 412
