Ir para o conteúdo principal
Toshiba Satellite E45-B4100 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite E45-B4100 Hard Drive Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 2, imagem 1 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Pro Tech Toolkit
    $74.95
    Comprar
    • Be sure to use ESD-safe tools, we recommend using the iFixit Pro Tech Toolkit
  5. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 5, imagem 2 %32
    • Unplug the Hard Drive from the Motherboard.
  6. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 6, imagem 2 %32
    • Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
  7. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 7, imagem 2 %32
    • Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
    • Remove the USB Port Circuit Board.
  8. Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite E45-B4100 Hard Drive Replacement: passo 8, imagem 2 %32
    • Gently remove the hard drive.
Conclusão
4 outras pessoas executaram este guia.
Delaney
Membro desde: 10/11/16
104 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-4, Leahy Fall 2016 Membro de USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
Membros da 3
Autoria de 10 guias
Um comentário
By and large this and the B4200 guide are interchangeable. I followed both when reviving my B4100, as the pictures the respective authors show the components from different angle. Good stuff; thank you!
Kntai - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,430
