Ir para o conteúdo principal
Toshiba Satellite E45-B4100 Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Pro Tech Toolkit
    $74.95
    Comprar
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 5, imagem 1 %32
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 6, imagem 1 %32
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: passo 7, imagem 1 %32
    • Remove the attachment from the Processor by gently rotating and lifting.
Conclusão
Uma outra pessoa concluiu este guia.
Brendan Sweeney
Membro desde: 10/11/16
182 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-4, Leahy Fall 2016 Membro de USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 610
