Ir para o conteúdo principal
Toshiba Satellite E105-S1602 Charging Port Replacement
O que você precisa
  1. Toshiba Satellite E105-S1602 Charging Port Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement, Battery: passo 1, imagem 2 %32
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 2, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 2, imagem 2 %32
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Charging Port Replacement, Keyboard: passo 3, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement, Keyboard: passo 3, imagem 2 %32 Toshiba Satellite E105-S1602 Charging Port Replacement, Keyboard: passo 3, imagem 3 %32
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 4, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 4, imagem 2 %32
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 5, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 5, imagem 2 %32
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 7, imagem 1 %32
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 8, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 8, imagem 2 %32
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Charging Port Replacement, Front Panel: passo 9, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement, Front Panel: passo 9, imagem 2 %32
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 10, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 10, imagem 2 %32
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 11, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 11, imagem 2 %32
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 12, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 12, imagem 2 %32
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 13, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 13, imagem 2 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 13, imagem 3 %32
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 14, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 14, imagem 2 %32
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 15, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 15, imagem 2 %32
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 16, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 16, imagem 2 %32
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 17, imagem 1 %32
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Toshiba Satellite E105-S1602 Charging Port Replacement, Charging Port: passo 18, imagem 1 %32
    • Locate the charging port on the computer.
  19. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 19, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 19, imagem 2 %32
    • Turn the laptop so the side with the charging port is facing you.
    • Using a tweezer, lift up the charging port to take it out of its retaining slot.
    • Pull the wires out from their nesting place in between the disc drive and the computer body.
  20. Toshiba Satellite E105-S1602 Charging Port Replacement: passo 20, imagem 1 %32 Toshiba Satellite E105-S1602 Charging Port Replacement: passo 20, imagem 2 %32
    • Locate the base of the plug on the motherboard.
    • Pull up on the plug to remove the charging port from the motherboard.
Conclusão
Ian Washburne
Membro desde: 01/11/13
59 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-21, Forte Winter 2013 Membro de Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 10,139
