Ir para o conteúdo principal
Toshiba Satellite Click 2 Pro Wifi Card Replacement
O que você precisa
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: passo 1, imagem 2 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 2, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 2, imagem 2 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 2, imagem 3 %32
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 3, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 4, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 4, imagem 2 %32
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 5, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 5, imagem 2 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 5, imagem 3 %32
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 6, imagem 1 %32 Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 6, imagem 2 %32
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 7, imagem 1 %32
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: passo 8, imagem 1 %32
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 9, imagem 1 %32
    Comprar
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: passo 10, imagem 1 %32
    • Remove wifi card.
Conclusão
Paul DeOrsey
Membro desde: 03/10/16
893 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-3, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-3, Catania Spring 2016
UMASSD-CATANIA-S16S4G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 429
