Ir para o conteúdo principal
Toshiba Satellite Click 2 L35W-B3204 Screen Replacement
O que você precisa
  1. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: passo 1, imagem 1 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: passo 1, imagem 2 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 2, imagem 2 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 3, imagem 2 %32 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 3, imagem 3 %32
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: passo 4, imagem 1 %32
    • Your screen is now completely detached from the internal components.
Conclusão
Lexi Lannigan
Membro desde: 10/17/18
753 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Membro de UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
Membros da 6
Autoria de 12 guias
Um comentário
This instruction set was VERY useful, since it focused on the exact device that I have, and had great photos to accompany the steps. TC
Thomas Cirillo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Duração total: 1,519
