Ir para o conteúdo principal
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
O que você precisa
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 2, imagem 1 %32
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 3, imagem 1 %32
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 4, imagem 1 %32
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 5, imagem 1 %32
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 6, imagem 1 %32
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, imagem 1 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, imagem 2 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: passo 7, imagem 3 %32
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, imagem 1 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, imagem 2 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 9, imagem 1 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 9, imagem 2 %32
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 10, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, imagem 1 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, imagem 2 %32 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: passo 11, imagem 3 %32
    • Open the laptop and remove the display assembly from the keyboard assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Hook
Membro desde: 03/25/19
439 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S1-G6, Hovde Fall 2019 Membro de IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 309
