Ir para o conteúdo principal
Toshiba Satellite C875-S7304 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 3, imagem 1 %32
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 4, imagem 1 %32
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, imagem 2 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 7, imagem 3 %32
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, imagem 2 %32 Toshiba Satellite C875-S7304 Hard Drive Replacement: passo 8, imagem 3 %32
    • Pull the hard drive laterally to disconnect it from the laptop.
    • Use the clear tab to lift the hard drive out of the laptop.
    • When reassembling, make sure the hard drive lies flat in the laptop before reconnecting it.
Conclusão
Taimoor Arshad
Membro desde: 09/04/19
381 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 29
Duração total: 1,086
