Ir para o conteúdo principal
Toshiba Satellite C855D-S5303 Disc Drive Replacement
O que você precisa
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, imagem 1 %32 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, imagem 2 %32 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: passo 1, imagem 3 %32
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 2, imagem 1 %32
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite C855D-S5303 Disc Drive Replacement: passo 3, imagem 2 %32
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Conclusão
Uma outra pessoa concluiu este guia.
Courtney Burns
Membro desde: 10/20/16
863 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 22
Ao todo: 411
