Ir para o conteúdo principal
Toshiba Satellite C855D-S5109 Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 2, imagem 2 %32
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 3, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 3, imagem 2 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 3, imagem 3 %32
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: passo 4, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: passo 4, imagem 2 %32
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 5, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
  6. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: passo 6, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: passo 6, imagem 2 %32
    • Remove the twelve 6 mm screws from the back of the laptop with a Phillips #00 screwdriver.
    • There are 12 screws holding the back panel on the laptop. Two of the screws are located underneath the service panel.
  7. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 7, imagem 3 %32
    • Remove the DVD RW Drive by sliding it out.
    • Use a jimmy to pry open the back panel.
    • Pull the back panel of the laptop off, exposing the motherboard and other inside components.
  8. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 8, imagem 1 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 8, imagem 2 %32 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: passo 8, imagem 3 %32
    • The cooling fan is in the bottom right corner of the laptop.
    • Unplug the small red and blue wire connecting the cooling fan to the motherboard.
    • Remove the two 3 mm screws securing the fan to the motherboard with a Phillips #00 screwdriver.
    • Remove the fan from the laptop.
Conclusão
Brook Ostrander
Membro desde: 09/27/21
169 Reputação
Autoria de 2 guias
Equipe
Casper College, Team 1-3, Lareau Fall 2021 Membro de Casper College, Team 1-3, Lareau Fall 2021
CASC-LAREAU-F21S1G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 299
