Introdução
If your device has slowed down or no longer has saving capacity, it's time for an upgrade. This guide will show you how to replace your RAM (Random Access Memory) when you need to expand your device's memory space.
O que você precisa
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Remove the single 7mm Phillips screw holding the panel in place using the J1S screwdriver.
Remove the back panel using the opening tool.
