Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
Pull out the keyboard gently and fold it backwards.
Pull out the connector attaching the keyboard to the main body of the laptop.
Uma outra pessoa concluiu este guia.
2 comentários
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
