Ir para o conteúdo principal
Toshiba Satellite C855-S5115 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 2, imagem 1 %32
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C855-S5115 Keyboard Replacement: passo 4, imagem 2 %32
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite C855-S5115 Keyboard Replacement: passo 5, imagem 2 %32
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Responder
Do you have to do anything with the connector before removing?
William - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 2,533
