Ir para o conteúdo principal
Introdução
Sticking and broken keys means it might be time for a new keyboard. This guide will show you how to remove and replace you Toshiba's keyboard.
Peças
Nenhum componente especificado.
  1. Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery. Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Carefully separate the keyboard from its assembly by pulling it out with the opening tool. Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Pull out the keyboard gently and fold it backwards. Pull out the keyboard gently and fold it backwards.
    • Pull out the keyboard gently and fold it backwards.
  5. Pull out the connector attaching the keyboard to the main body of the laptop. Pull out the connector attaching the keyboard to the main body of the laptop.
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Responder
Do you have to do anything with the connector before removing?
William - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 38
Duração total: 1,479
