Ir para o conteúdo principal
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: passo 1, imagem 2 %32
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 2, imagem 1 %32
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, imagem 2 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 4, imagem 3 %32
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 5, imagem 2 %32
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 6, imagem 2 %32
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: passo 7, imagem 2 %32
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 1,514
