Ir para o conteúdo principal
Toshiba Satellite C855-S5115 DVD Tray Replacement
O que você precisa
  1. Toshiba Satellite C855-S5115 DVD Tray Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  2. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 2, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 2, imagem 2 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 2, imagem 3 %32
    • Pry the back panel out of the laptop using the spudger tool
  3. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 3, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 3, imagem 2 %32
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  4. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 4, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 4, imagem 2 %32
    • Slide the HDD towards the sticker on the left.
  5. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 5, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 5, imagem 2 %32
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
  6. Toshiba Satellite C855-S5115 DVD Tray Replacement, DVD Tray: passo 6, imagem 1 %32
    • Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
  7. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 7, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 7, imagem 2 %32
    • Insert a plastic opening tool and follow the edges to open the panel.
  8. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 8, imagem 1 %32
    • Once open, locate the CD tray indicated in this picture.
  9. Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 9, imagem 1 %32 Toshiba Satellite C855-S5115 DVD Tray Replacement: passo 9, imagem 2 %32
    • Lift the tray up and out.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 29
Ao todo: 339
