Ir para o conteúdo principal
Toshiba Satellite C855-S5115 Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: passo 1, imagem 2 %32
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 4, imagem 2 %32
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 6, imagem 1 %32
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, imagem 1 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, imagem 2 %32 Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 7, imagem 3 %32
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 8, imagem 1 %32
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 9, imagem 1 %32
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 10, imagem 1 %32
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 11, imagem 1 %32
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 12, imagem 1 %32
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: passo 13, imagem 1 %32
    • Remove the CPU fan.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 37
Ao todo: 1,598
