Ir para o conteúdo principal
Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, imagem 1 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, imagem 2 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, imagem 3 %32
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, imagem 1 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, imagem 2 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, imagem 3 %32
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, imagem 1 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, imagem 2 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, imagem 3 %32
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 4, imagem 1 %32 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 4, imagem 2 %32
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
Conclusão
5 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
3 comentários
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - Responder
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 66
Duração total: 8,056
