Ir para o conteúdo principal
Toshiba Satellite C675-S7106 RAM Replacement
O que você precisa
  1. Toshiba Satellite C675-S7106 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite C675-S7106 RAM Replacement: passo 2, imagem 2 %32
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 RAM Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite C675-S7106 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0 head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite C675-S7106 RAM Replacement: passo 4, imagem 2 %32
    • Unclip and move the two metal clips on either side of one or either RAM stick.
    • Pull the stick outwards as you lift it upwards.
    • When reinstalling, ensure that the contacts are completely covered and connected.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Steakelum
Membro desde: 03/25/19
451 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Membro de UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 238
