Introdução
If your keyboard module is malfunctioning, you'll need to replace it. You’ll need a PH0 screwdriver and a rigid pry tool. The process itself is easy, just pay special attention when gently opening the ZIF connector.
O que você precisa
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Quase terminado!
Conclusão
