Ir para o conteúdo principal
Toshiba Satellite C675-S7106 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 2, imagem 2 %32
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 4, imagem 3 %32
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 5, imagem 2 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 5, imagem 3 %32
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 6, imagem 2 %32 Toshiba Satellite C675-S7106 Keyboard Replacement: passo 6, imagem 3 %32
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
Conclusão
Dinis Valcorba
Membro desde: 03/26/19
292 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Membro de UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 461
