Ir para o conteúdo principal
Toshiba Satellite C675-S7106 Battery Replacement
  1. Toshiba Satellite C675-S7106 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C675-S7106 Battery Replacement: passo 2, imagem 2 %32
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
Conclusão
Joshua Steakelum
Membro desde: 03/25/19
451 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Membro de UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 164
