Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Toshiba Satellite C660 HDD / RAM Memory Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: passo 1, imagem 1 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: passo 1, imagem 2 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: passo 1, imagem 3 %32
    • Remove the battery.
    • Unscrew 1x Phillips screw and disassemble the HDD / RAM memory cover.
  2. Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 2, imagem 1 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 2, imagem 2 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 2, imagem 3 %32
    • Use a plastic tool and an anti static gloves to pull out the memory modules.
    • If you have not, then hold the board only at the ends.
    • If you plan to make an upgrade, first of all check the specification of yours model. Depending of the Chipset and the producer, every laptop have a limit of the expansion of the RAM memory.
    • Check exactly type of the used memory modules. This models use DDR3 technology.
    • You can use modules with a different speed but the processor will work with them at the speed of the slower one.
    • Some modules will not work together.
  3. Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 3, imagem 1 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 3, imagem 2 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 3, imagem 3 %32
    • Now let's remove the HDD.
    • Remove the hard drive by sliding it away from the port towards the screw hole.
  4. Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 5, imagem 1 %32 Toshiba Satellite C660 HDD / RAM Memory Replacement: passo 5, imagem 2 %32
    • Unscrew the 4x Phillips screws and separate the HDD from the HDD caddy.
    • You can upgrade your HDD to maximum 1TB.
Conclusão
5 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.182 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.519 guias
3 comentários
I dunno, I would class this as easy peasy. One captive screw. No need for tool to remove ram, it pops up when you flex open the metal bits. Doing it with fingers is way easier.
While you can remove the 4 screws to remove and transplant the bit of plastic onto the new drive, a dab of sugru to secure 20 quid ssd drive will do the job. Upgrading these things tales less than 5 minutes.
Beyond utility - Responder
Can I replace the HDD with a SATA SSD?
Steven Jamolin - Responder
To Steve Jamolin:No
WideRio Saeas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 84
Duração total: 11,829
