Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remov the narrow plastic lid and unscrew 4x Phillips screw.
This is the internal CMOS / BIOS battery. Use small screwdriver to remove it.
13 outras pessoas executaram este guia.
4 comentários
what battery do i need
The receptacle that the battery goes into is loose and not making contact on the (+) terminal. This is a shoddy design. You can test it by pressing the receptacle down and powering the laptop. Works fine. You cannot solder the terminal for fear of upsetting the motherboard. Any solutions.
Until I find one, I continue to press F1, go to Control Panel and set the time and date every time I power on the laptop.
same battery CR2032 for Toshiba sattelite L775 G10 ?
thx
