Ir para o conteúdo principal
Toshiba Satellite C660 CMOS / BIOS Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: passo 1, imagem 1 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: passo 1, imagem 2 %32
    • Disconnect the charger and the battery.
  2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 2, imagem 2 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 2, imagem 3 %32
    • Remov the narrow plastic lid and unscrew 4x Phillips screw.
  3. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 3, imagem 3 %32
    • Remove the keyboard.
  4. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 4, imagem 1 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 4, imagem 2 %32 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 4, imagem 3 %32
    • This is the internal CMOS / BIOS battery. Use small screwdriver to remove it.
  5. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: passo 5, imagem 1 %32
    • And that's it!
Conclusão
13 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
187.973 Reputação
330 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
311 Membros
1.197 Guias de autoria
4 comentários
what battery do i need
allan mccauley - Responder
This is a CR2032 battery
Hyperion - Responder
The receptacle that the battery goes into is loose and not making contact on the (+) terminal. This is a shoddy design. You can test it by pressing the receptacle down and powering the laptop. Works fine. You cannot solder the terminal for fear of upsetting the motherboard. Any solutions.
Until I find one, I continue to press F1, go to Control Panel and set the time and date every time I power on the laptop.
Hari Razdan - Responder
same battery CR2032 for Toshiba sattelite L775 G10 ?
thx
gagalot Eric - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 158
Últimos 30 dias: 597
Duração total: 43,253
