Ir para o conteúdo principal
Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
O que você precisa
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): passo 1, imagem 1 %32 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): passo 1, imagem 2 %32
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: passo 2, imagem 1 %32
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: passo 3, imagem 1 %32
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
Conclusão
3 outras pessoas executaram este guia.
Shelby Kunz
Membro desde: 04/19/13
69 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-20, Maness Spring 2013 Membro de Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 3,032
