Introdução
Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
O que você precisa
Turn the laptop over and place upside down on a flat surface.
Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
3 outras pessoas executaram este guia.
