Ir para o conteúdo principal
Toshiba Satellite C655D-S5084 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: passo 3, imagem 1 %32
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
Conclusão
4 outras pessoas executaram este guia.
Shelby Kunz
Membro desde: 04/19/13
69 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-20, Maness Spring 2013 Membro de Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 27
Duração total: 3,523
