Introdução
If your computer is running slow and needs a little pick me up, one option is to replace or upgrade your hard drive. This guide will show you how to remove your hard drive and install a replacement in your Toshiba Satellite C655D-S5084.
O que você precisa
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
4 outras pessoas executaram este guia.
