Ir para o conteúdo principal
Toshiba Satellite C655-S5142 RAM Replacement
O que você precisa
  1. Toshiba Satellite C655-S5142 RAM Replacement, RAM: passo 1, imagem 1 %32 Toshiba Satellite C655-S5142 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Ensure that your laptop is turned off and the battery has been removed
    • Flip over your laptop where the battery side is closest to you.
  2. Toshiba Satellite C655-S5142 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite C655-S5142 RAM Replacement: passo 2, imagem 2 %32
    • Unscrew the singlular screw in plate with a Phillips #1 screwdriver.
    • The screw does not come all the way out of the plastic plating, instead there is a protector that keeps it in place for you even when fully unscrewed.
  3. Toshiba Satellite C655-S5142 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite C655-S5142 RAM Replacement: passo 3, imagem 2 %32 Toshiba Satellite C655-S5142 RAM Replacement: passo 3, imagem 3 %32
    • To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
    • Once pushed outwards, the first RAM stick will pop up at an angle
    • After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
Conclusão
Uma outra pessoa concluiu este guia.
Hunter Gonsalves
Membro desde: 03/24/19
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 252
