Ir para o conteúdo principal
Toshiba Satellite C655-S5142 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Unplug your computer, and make sure that it is shut off before starting
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 2, imagem 2 %32
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 3, imagem 2 %32
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C655-S5142 Keyboard Replacement: passo 4, imagem 2 %32
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Kozlowski
Membro desde: 03/21/19
244 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 333
