Ir para o conteúdo principal
Toshiba Satellite C55Dt-A5306 Disc Drive Replacement
O que você precisa
  1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Battery: passo 1, imagem 1 %32
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 2, imagem 1 %32
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Back Cover: passo 3, imagem 1 %32
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 4, imagem 1 %32
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 5, imagem 1 %32
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: passo 6, imagem 2 %32
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: passo 7, imagem 1 %32 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: passo 7, imagem 2 %32
    • Slide the disc drive to the left. It should come off with ease.
Conclusão
zeena qiryaqoz
Membro desde: 01/17/17
301 Reputação
Autoria de 3 guias
Equipe
Um comentário
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
ed_l_grey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 425
