Ir para o conteúdo principal
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
O que você precisa
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, imagem 1 %32 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, imagem 2 %32 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: passo 1, imagem 3 %32
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 2, imagem 1 %32
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 3, imagem 1 %32 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 3, imagem 2 %32
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 4, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 5, imagem 1 %32
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 6, imagem 1 %32
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: passo 7, imagem 2 %32
    • Pull the fan and heat sink away from the motherboard.
Conclusão
Laura Tamayo
Membro desde: 02/14/19
678 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G4, Leahy Spring 2019 Membro de USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
Membros da 4
Autoria de 10 guias
Um comentário
My Toshiba laptop shut down exactly after 30 minutes why is the reason? Please tell me the problem & the solution.
Afetes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 19
Últimos 30 dias: 23
Duração total: 401
