Ir para o conteúdo principal
Toshiba Satellite C55D-B5206 Trackpad Replacement
O que você precisa
  1. Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 2, imagem 2 %32
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Trackpad Replacement, Back Casing: passo 3, imagem 1 %32
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 4, imagem 1 %32
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 5, imagem 2 %32 Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 5, imagem 3 %32
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32
    • Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
  7. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 7, imagem 1 %32
    • Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
    • Gently pull the blue ribbon cable free.
  8. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 8, imagem 1 %32
    • Use a small Philips screwdriver to remove the screw shown.
  9. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 9, imagem 2 %32
    • Push the two gray tabs out on the large wire plug shown.
    • The tabs only need to be pressed out a few millimeters, not all the way.
    • The plug can now be carefully pulled out.
  10. Toshiba Satellite C55D-B5206 Trackpad Replacement: passo 10, imagem 1 %32
    • Gently lift the trackpad to remove it.
Conclusão
Elaine Butler
Membro desde: 04/12/22
265 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-2, Beck Spring 2022 Membro de IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 206
