Pular para o conteúdo principal
  1. First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Once you take the screws out, take the battery off; it should slide off easily.
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Then, carefully take off the back casing of the laptop and set it aside.
    • Then, carefully take off the back casing of the laptop and set it aside.
  6. This is where the RAM is located that you will be replacing.
    • This is where the RAM is located that you will be replacing.
  7. There are two clips holding the RAM in place.
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  8. Gently remove the RAM and insert replacement.
    • Gently remove the RAM and insert replacement.
Conclusão
Uma outra pessoa concluiu este guia.
David Amodei
Membro desde: 30-11-2017
145 reputação
Autoria de 1 guia
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 248
