Ir para o conteúdo principal
Toshiba Satellite C55D-B5206 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 2, imagem 2 %32
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: passo 3, imagem 1 %32
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 4, imagem 1 %32
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, imagem 2 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 5, imagem 3 %32
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, imagem 2 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 7, imagem 3 %32
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 8, imagem 2 %32
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, imagem 2 %32 Toshiba Satellite C55D-B5206 Hard Drive Replacement: passo 9, imagem 3 %32
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Conclusão
7 outras pessoas executaram este guia.
Michelle
Membro desde: 09/17/15
175 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-5, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
Membros da 4
Autoria de 18 guias
2 comentários
Thanks.. Really helped out..
SpeedyBlanco - Responder
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 4,680
