Introdução
This guide will show you how to easily remove a CD drive to clean it or replace it with a new one. Do not be intimidated by the size of the CD-ROM drive, it is fairly easy to remove.
O que você precisa
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
The 7 mm Philips#1 screw has been removed in the back casing removal.
Place thumb on the edge of the CD-ROM drive.
Gently slide the CD-ROM drive towards your palm.
5 outras pessoas executaram este guia.
