Ir para o conteúdo principal
Toshiba Satellite C55D-B5206 CD Drive Replacement
O que você precisa
  1. Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 2, imagem 2 %32
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 CD Drive Replacement, Back Casing: passo 3, imagem 1 %32
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 4, imagem 1 %32
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, imagem 2 %32 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 5, imagem 3 %32
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 CD Drive Replacement, CD Drive: passo 6, imagem 1 %32
    • The 7 mm Philips#1 screw has been removed in the back casing removal.
    • Place thumb on the edge of the CD-ROM drive.
    • Gently slide the CD-ROM drive towards your palm.
  7. Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55D-B5206 CD Drive Replacement: passo 7, imagem 2 %32
    • Lift away the CD-ROM drive.
    • You should feel the CD-ROM drive detach from the connector port.
    • The drive should slide out and lift away with little resistance. There is no need to slide the drive roughly.
Conclusão
5 outras pessoas executaram este guia.
Tayyaba
Membro desde: 09/24/15
523 Reputação
Autoria de 4 guias
Equipe
CSU Fullerton, Team 2-5, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 661
