Introdução
This manual provides a step by step guide to replacing the battery of a Toshiba C55D laptop.This is a fairly simple task and does not require a lot of time. The battery needs to be removed in order to disassemble other parts of the laptop as well as installing a new battery.
O que você precisa
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
