Ir para o conteúdo principal
Toshiba Satellite C55D-A5304 Fan Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5304 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the laptop is disconnected from all power sources and turned off.
    • Start with computer upside down with battery slot facing up.
  2. Toshiba Satellite C55D-A5304 Fan Replacement: passo 2, imagem 1 %32
    • Use the buttons of the sides of the battery to slide inwards and release the battery.
  3. Toshiba Satellite C55D-A5304 Fan Replacement: passo 3, imagem 1 %32
    • Take the battery out.
  4. Toshiba Satellite C55D-A5304 Fan Replacement, Fan: passo 4, imagem 1 %32
    • Open the back of the laptop using a pry tool.
  5. Toshiba Satellite C55D-A5304 Fan Replacement: passo 5, imagem 1 %32
    • Once you see the fan, to make the cleaning process more convenient use a screwdriver to unscrew the 4mm screws on the fan.
    • To the immediate right of the fan the wiring harness is located. Disconnect this also to remove the fan.
  6. Toshiba Satellite C55D-A5304 Fan Replacement: passo 6, imagem 1 %32
    • Use a microfiber cloth and/or compressed air to clear any dust or clogging.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Verre
Membro desde: 03/13/23
211 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 125
