Ir para o conteúdo principal
Toshiba Satellite C55D-A5201 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 2, imagem 1 %32
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 3, imagem 2 %32
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 5, imagem 1 %32
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 6, imagem 1 %32
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 7, imagem 3 %32
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 8, imagem 2 %32
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, imagem 2 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 9, imagem 3 %32
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 10, imagem 1 %32 Toshiba Satellite C55D-A5201 Keyboard Replacement: passo 10, imagem 2 %32
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
Conclusão
13 outras pessoas executaram este guia.
Kari Byrd
Membro desde: 03/24/15
614 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 6-5, Shaver Spring 2015 Membro de Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 5,822
