Ir para o conteúdo principal
Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: passo 6, imagem 1 %32 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: passo 6, imagem 2 %32 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: passo 6, imagem 3 %32
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: passo 7, imagem 1 %32 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: passo 7, imagem 2 %32
    • Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
  8. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: passo 8, imagem 2 %32
    • The card will pop up; gently pull the card out of the port.
    • Unplug the wireless antenna cables attached to the card.
    • Remember how the cables were connected to assure you do not cross the Bluetooth and wireless connections by accident.
Conclusão
Ryan Smith
Membro desde: 10/25/19
187 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 43
Duração total: 916
