Ir para o conteúdo principal
Toshiba Satellite C55D-A5108 RAM Stick Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 2, imagem 1 %32
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 3, imagem 1 %32
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 5, imagem 1 %32
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: passo 6, imagem 1 %32
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
Conclusão
Geoffrey Souza
Membro desde: 10/25/19
327 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 243
