Ir para o conteúdo principal
Toshiba Satellite C55D-A5108 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: passo 2, imagem 1 %32
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: passo 3, imagem 1 %32
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: passo 5, imagem 1 %32
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55D-A5108 Keyboard Replacement: passo 6, imagem 2 %32
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Conclusão
Michael Medeiros
Membro desde: 10/25/19
150 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 241
