Ir para o conteúdo principal
Toshiba Satellite C55-a5310 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Toshiba Satellite C55-a5310 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  4. Toshiba Satellite C55-a5310 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-a5310 Keyboard Replacement: passo 4, imagem 2 %32
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  5. Toshiba Satellite C55-a5310 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-a5310 Keyboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to remove the keyboard from the laptop.
  6. Toshiba Satellite C55-a5310 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55-a5310 Keyboard Replacement: passo 6, imagem 2 %32
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
Conclusão
3 outras pessoas executaram este guia.
Kari Rodgers
Membro desde: 02/08/18
482 Reputação
Autoria de 4 guias
Equipe
2 comentários
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - Responder
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
Jeff Breuer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,234
